Teledyne Lars glycol boiler - air in system
19 Mar 2004
I have a Teledyne Lars domestic glycol boiler system that is making a noise like it has air trapped. The problem started after a company changed the glycol and installed a bypass valve. the mix is about 60% glycol, system pressure = 16 PSI. I get lots of foam from the drain valve. The glycol is the safe type. Is there an antifoam agent that I can use?
