Hi all,
I have an extension (four core cable) running from the BT master socket to a slave socket in the living room for a cordless phone and broadband connection. Up to last week this was all running smooth then for no apparent reason the line has gone dead. I tested the phone in the master socket within the linebox and the master wiring is fine but i have no dial tone or connection on my extension socket.
I redid the connections at the linebox (idc terminals) to no avail and have changed the faceplate of the slave socket (screw terminals) as the terminals looked slightly dull so i wondered if they had oxidised impairing the connection but still no signal. My next step is probably to get some new cable and re-wire the whole lot but before i do, any ideas what may have caused the sudden fault?
My only other thought is whether its possible that the blades in the idc connection of the linebox are worn and hence not making proper contact. If so is it possible to buy just the faceplate for the box rather than getting stung by BT to come out and fit a whole new box?
Thanks.
Thanks.
