Just bought an unused 160 litre cylinder off Eblag. It will go up in the attic in tandem with the existing cylinder for my solar project. May I have the benefit of your experience please?
(Conventional gravity fed system BTW)
I see Screwfix do a blanking plug for the immersion heater hole. Why are there FIVE inlet-outlet bosses and can I also buy a blanking plug for the unused boss halfway up the side?
Full up this will weigh 160 kgs + 18 kgs so 178 kgs plus fittings and I plan to encase it in an insulated box. Is it okay to put this on a board on the rafters or should I look around for somewhere with at least a stud wall underneath for some support?
It will need to be quite near the 1st floor electrics, which are in a messy rat's nest of junction boxes on a board on the attic floor. Are there any regs about proximity to electrics?
Our HW is quite sluggish all over the house, never worked out why, I plan eventually to fit a low boost pump to the showers. Do you think adding this cylinder in tandem will reduce the flow even further?
Finally, what would happen if the loop of pipe out of the top got to within a few inches of the water level in the supply tank? Am I likely to get an airlock and so should I fit a bleed valve at the highest point?
PS: Yes, I plan to test fill the cylinder before heaving it up through the attic hatch! It will be a tight squeeze but should go OK.
