Help required for some pensioners. We have extractor fans in each of our bathrooms which are triggered by flow switches on the cold water feed to the showers (one shower is electric so fed by cold water only, the other is a mixer with cold and hot feeds). These work correctly most of the time but occasionally the fan comes on when water is used elsewhere in the house and very occasionally when we operate the light switches hidden behind the tiles. This seems to happen for a few days then things revert to normal operations.
We are not able to identify source of the problem as it is intermittent so we are looking for ideas.
We replaced the flow switches a few years ago when we first had the problem and things worked for a couple of years but then started up again. We also recently fitted a non-return valve next to one flow switch but this has had no effect even though this is the last tap on the system. Any suggestions about what may be causing the problem or ideas for an alternative solution that would apply to both showers would be welcome but we don’t really want a PIR or humidistat.
