Temporary blank ends
13 Sep 2007
Bournemouth
Hi all,
looking to remove two small rads that are both next to each other on a spur in my kitchen (so I can get behind and remove tiling and re-plaster ,before getting a heating engineer in to replace with one larger and more efficient rad when he swaps my boiler).
I am comfortable draining the system and removing the rads, but I need to temporarily blank off the spur for a couple of weeks until the engineer is here to do the boiler and fit the new rad.
I am planning to remove the rads, cut the spur pipes so they're out the way and push on some plastic blank ends so I can work on the walls. Hoping to re-fill and run the heating between doing this and re-fitting.
My question is, are the blank-ends suitable for a temporary repair, while still giving me use of heating?
Yep, so long as the pipes are cut square, aren't chrome or distorted in shape, these are fine.
John :)
