- Joined
- 7 Oct 2021
- Messages
- 1
- Reaction score
- 0
- Country
Hi I'm currently doing a plumbing course and for my nvq I have a few questions to answer.
Could someone help me the steps for the following :
1.temporary decommissioning
2.Insuffient pipe clips on hot water pipe work to bath(hot water fed from combi boiler)
3.Isolation valve leaking on hot water supply to mixer shower( new valve required)
4.cold water storage cistern inadequate for demand(larger cistern to be installed)
5.central heating circulating pump not working (needs replacing)
6. Radiator blocked(hot and cold patches) over surface( combi boiler system)
7.isolation valve passing on filling loop causing boiler PRV to discharge
8.blocked hand basin trap
9.blocked waste pipe
10.leaking waste pipe elbow from wash basin
I just need the steps as if you were at a customers home what you would do. Each statement starts with
Inform the customer
Protect the fabric area
Isolate supply at .....
Can anybody help. Thank you in advance
Inform the customer
