Hello Forum Members,
I need suggestions on the best way to temporarily fix a hole in the slate roof of my house from the inside (i.e. from the loft area) till I can get the roof retiled properly. Objective is to prevent or minimise the ingress of water into the loft area.
Due to the recent bad weather the roof of my house has developed a "hole". The roof is a slate roof and 2 of the slates seem to have snapped in half leaving a fairly significant hole in the roof. Unfortunately I do not have a photo on hand but the hole is irregularly shaped and is about 10 cm X 10 cm in size.
The roof is very old and does not have a felt layer under the tiles. Therefore all water entering the roof structure falls onto the plasterboard ceiling... I noticed a significant brown damp patch a 2 days ago on the bedroom ceiling which is how I knew that the roof was leaking.
The roof is a very old roof and I was planning to get the tiles changed sometime in the next 1-2 years. However I will now try and get it done in the next 6 months.
I cannot access the roof from outside for multiple reasons including safety, height, risk of causing more damage to the roof, ladder will have to be on neighbour's flat roof etc.
But I want to know how I can temporarily fix the hole till then?
Thank you.
Thank you.
