Temporary Toilet installation during bathroom refit.
1 Mar 2010
London
Hi all,
I need some advice concerning the fitting of a new bathroom which I hope you can help with. I should mention that this is our only bathroom/WC….!
I am concealing the toilet cistern behind a PB/Aquapanel wall which will be plastered prior to being tiled (not the whole wall will be tiled, hence the need to plaster). The pan I intend to fit is floor-mounted, but flush with the wall to hide the soil pipe (using a flexi soil pipe connector). As the plaster will take ~4days to dry before I can tile, I need to temporarily fit the toilet a few mm away from the wall. When dry I can then remove the pan, tile and install properly.
Q1) Could I just let the pan sit on the floor and use a couple of nuts on the studs from the pan mounting frame to stop the pan sliding back and touching the wet plaster?
Q2) How hard would it be to drill through floor tiles (yet to be chosen) and SLC to screw the pan to the floor? Do I need to pre-drill all the way through to the wooden sub-floor?
Any other pointers or problems I should be warned about?!!
Many thanks
GW
