Evening
When I was removing some MK double sockets ( new house only 3 years old ) I found that the terminal screws to the live, neutral and earth cables were very tight ?
In some instances the terminal screw on the live connection stripped and so I had to cut the cable away so that I could removed the socket.
I understand that the latest edition of the regulations recommend that a torque screwdriver is used, however I also learned that many of the socket manufacturers do not specify a torque figure ?
Could anyone please advise is it possible to overtighten the terminal screws to the point where you can potentially cause a problem ?
In my case the live terminal always seemed to be the one which stripped - does the flowing current cause the fittings to tighten up through time ?
Many thanks.
Many thanks.
