I have been on the roof to check on the terminal on the chimney stack which is loose, as it's been up there for 17 years.
The terminal (cowl?) is loose, the flexible tube in the flue is just long enough to reach the benching on the top of the chimney stack, so i can't push it into the terminal.
I pushed the terminal back into the hole in the top of the chimney stack for the time being to stop it (the terminal) rattling about in the wind.
There are no holes in the terminal for screws to fasten the flexible pipe to.
can i ask if the terminal (cowl?) should be fastned to the flexible tubing in the chimney flue?.
Can i fix the terminal to the chimney stack in place using concrete repair product (silicone sulphate it hink it's called) ?
thanks for any help
thanks for any help
