Terraced House-Cavity Insulation?
30 Jun 2008
Suffolk
What kind of costs would I be looking at for cavity wall insulation in a 1940's terraced house? Its a 3 bedroom and an inner one of a block of four, (no gable end). How long to recoup the costs, (approximately). We have GCH and double glazing, (UPVC to rear, wooden to front). Loft is insulated and centre section T&G Boards for walking/storage. Is there a risk that if we get it done it will also spread sideways and partially insulate the houses on each side or are there barriers to prevent this? (Don't see why I should pay to help warm their houses!!)
Thanks John.
That is most helpful and well worth looking in to.
How wide is the cavity? If you measure at a doorway or window from inside to out - how thick is it?
The installer will need to form a hole at the top and bottom of the wall to insert a spacer at the junction between the two houses. This prevents insulation being blown into the cavity of your neighbour's house.
Read more: Insulation FAQ | Find Detail on Loft Insulation & Cavity Wall Insulation DIY, Regulation & Cost http://www.thinkinsulation.co.uk/faq.htm#cavity-12#ixzz1fUhXi4ij
Thanks Alistair. An interesting link and very informative.
