How?with a multimeter
Note, some transformers do not work if there is no load on the output side.
If you have a suspect transformer I would
Put a known working lamp on the output side of the tranny.
If that lamp does not work then
check there is power going in to the input side (needs multimeter but this has to be done with the power on)
The other common reason for a tranny to stop working is if someone has put the wrong wattage lamps in.
Most of the transformers do not have an iron transformer with windings so a resistance measurement will not work.
Mostly they are electronic components that will "transform" 230 volts AC to 12 volts (sort of) AC.
Think I said all that before breakfast!
should be a belt and braces method.Put a known working lamp on the output side of the tranny
