Hi i have two lights in conservatory which are both simple spurs of lighting circuit. One of the lights failed to light and a bulb chaonge didnt solve the problem. I swapped the fittings and the one that failed to light worked and the one that previous worked didnt suggesting it could be the switch. I bypassed the switch but no change. There is power to the live terminal of the light (checked using a neon tester) but the tester also lit up on the neutral! Should this happen. The light has worked fine for months by the way. Any ideas?
