If i record the temp of the CH flow from the Boiler mate and it is 77 degrees (as required by the MI's) does this mean that the whole cylinder is heated to the same temp? - if so what temp should the DHW out be (before the blending valve)?
if taking the CH flow temp is not the recommended way to test the store temperature then what is?
