Testing a Three Way Valve
16 May 2007
Bournemouth
Hello,
I have a Glow-worm Ultracom 30cxi Condensing Boiler.
Inside is a 'three way valve'. This valve is controlled via what I assume to be an actuator (with micro-switches?) connected to 4 wires, white, orange, blue & green.
Q1) is the actuator to control the valve position which is returned via a spring or an actuator with full powered in AND out control? (if you get my drift).
Q2) Does anyone know which wires to put a meter across to test for an 'on' (move the actuator) voltage?
Thanks,
Andy
Thanks chap.
Good diagram, but I *think* that is for external mains wiring of a complete heating system.
What I am taking about is INTERNAL wiring to a three port valve from the control board within the combi-boiler itself.
Jist of the matter is that I want to know if the control board is shagged or if the actuator 'motor' on the three port valve is shagged.
Cheers,
Andy
