Evening folks,
I've built a couple of portable distro's (32A plugs to small CU's with RCD's and MCB's out to 13A sockets etc), and 3 of 4 are fine, the RCD tests ok and no bother.
The 4th one is causing a bit more of a strange 'un.... It's a proteus 40A RCD with a functional earth cable (as detailed here - //www.diynot.com/forums/viewtopic.php?t=88594 ) and as advised I connected the earth cable to the earth bar.... In order to test the distro I've plugging it into a socket in the house (via a 13A to 32A adapter), however when I test the proteus RCD (with the test button) it trips out, and also trips the main RCD in the CU in the house (and I get into trouble for the power going off ).
Is the RCD FUBAR'd or is this ok for that type of RCD (all the others test fine and don't have a functional earth). And should I chuck it???
Cheers
Cheers
