testing and flushing a new radiator
30 Aug 2010
London
Hi guy and gals. I am expecting a delivery of a new cast iron radiator. I was told that the radiator will need to be tested and flushed before being installed. Should I flush it with a garden hose? To test it, is it enough to plug the other side with my finger and watch out for any leaks?
No on both points.
If it is an old radiator, it will need to be power flushed by someone with a machine. They would use chemicals to help remove sediment from within the radiator.
The radiator will need to be tested under pressure comparable to what would be in your system. How that would be done without fitting the radiator, i don't know but if you are having someone flush the radiator, they may also be able to pressure test it
No on both points.
The radiator is brand new so no need to remove sediments. Nevertheless, i was instructed by 21 Century Radiators to flush it. How shal i do that?
I can easily fit the radiator and test it like that. Is that what you plumbers do normally?
Sorry i missed the fact it was new.
In that case, I think flushing it with a garden hose would be fine. Im sure there wouldn't be much inside it but double check with the suppliers that that would be ok.
Yes fit the radiator as you would, fully open the valves on either side and periodically check for leaks. I would give it at least 48 hours under pressure to ensure that it's ok.
