So the CH picks one of the hottest days of the year to malfunction.
Came in this evening while the HW cycle was running & noticed that the rads were hot. The system is fitted with a Honeywell V4073A1039 three-way valve. If I understand correctly, the valve must be somehow stuck in it's middle position if both HW & CH are being supplied?
I'd appreciate some help on diagnosing this correctly please.
Edit
The manual lever was completely free so I've removed the head. It eventually twanged back to the home position but moving it back, it's clicky & notchy (technical terms there!). So I guess the gearing is shot & the head needs replacement?
Next question, Google suggests that the valve should be turnable by hand over a travel of approx 1/4 turn. I can only turn mine with pliers & only over approx 1/8 turn. Does that suggest that the valve is also shot?
Edit
