Hi
I am wanting to test for voltage in a lighting circuit. Basically, I have added a new bedroom light and it is not working. It's the sort with a built in transformer. I have had to shorten the steel cable (which supports the light from the ceiling) and also the cable from the light to the transformer. I am wanting to test for voltage FROM the transformer.
Transformer output is 150W (says 11.5 VAC MAX 150W).
I have the following multi-meter, just want to know what setting I need to check for the required voltage. Do I also need to put the red probe plug into the left hand 10A max socket?
Need to get this light working before it gets dark.
Many thanks.
Many thanks.
