hello
you see when you do the Zs test, and on the top of the NICEIC, schedule of test results for the installation part at the top right hand corner it has asks for the Zs, and maximum prospective Fault current, i always thought that Zs is the whole system that has to be test, but yet the book says you have isolate the supply and the earth to do the test and the test is done on the incoming terminals i thought that this test is Ze for external part???
then when you go to do the test results for each circuit, and it asks for the Zs again, that means it is for the the whole circuit doesnt it??and does the Zs value here have to be the same as the one in supply in the supply characteristics??
could somebody please explain the difference between the two of them please im lost
