Texecom 48W ATS Path Fault on com2 - ComGSM
5 Jan 2013
Surrey
My system was working fine up to last Sunday
Configuration
Premier Elite 48-W(v2.11)
COM1 - COMWiFi - only local access for wintex
COM2 - ComGsm - vodafone SIM
It is now reporting ats fault and it is coming back every time it is cleared
RSSI = -55dBm
I am able to send a text from keypad - ComGsm seems to be fine
But ComGSm is not talking to panel
After reset of com2 when I press 0
Atz and counting...
It is not talking to panel
Q) It was working fine, was able to receive SMS from panel for alarm, status and etc... and the signal is always good, what could be the reason for this failure
Is it a contract sim or pay as you go ?
Could be no network with is causing com 2 fault ?
Just a thought , the GSM unit tamper on the older units used to disconnect the GSM unit, also depending on panel and firmware , depending on dill switch setting , not reporting gsm tamper either. I had this a couple of years ago on a panel . A quick stretch on the GSM tamper switch did sort this issue
I bought and installed the system Jan 2016.
no idea of firmware on ComGSM
I have not touched the ComGSM after installing, I willremove the cover and check it
Thanks for the help, I did power down ComGSM by removing the cover and power it up ----> working fine.
