Texecom ats fault
17 Feb 2008
Berkshire
How do i access the smartcom to see what network it is accessing, think i may have it on a hub used as a repeater and want to change to my main hub ssid
Is it basically a case of doing what i did to originally set it up?
"Press and hold the WiFi button for 5 seconds until the WiFi LED starts blinking approximately once per second. 11 Connect a laptop or tablet to the WiFi SSID that starts “SmartCOM” followed by a number. NOTE: It can take up to 60 secs for the SSID to appear on your device. Please be patient. Click Connect and enter the passphrase when prompted. The passphrase can be found on the label inside the SmartCom. Once connected, open a web browser and in the address bar enter 192.168.2.1, then press return or refresh. A list of available WiFi networks should appear in the browser. Click the button next to the required connection and enter the WiFi passphrase. (Router password) Click “Connect”. The SmartCom will flash the WiFi LED quickly while it connects to the WiFi network. Once the connection is made, the LED will remain on permanently. The SmartCom is now connected to the WiFi and ready for use."
Basically yes, any problems give us a shout, sometimes the wifi can be awkward when changing the settings but not 100% sure why that's the case.
