Texecom Chime On Timer
4 Jul 2014
Hello,
Texecom Premier Elite 88
Texecom Premier Elite LCDLP
Can someone please point me in the direction of how to configure some zones to chime but only within a specified time frame?
I would like to have some door contacts chime only between 6pm and 6am, outside of that time there should be no chime.
Don't think this is possible ?
You may have to turn chime on & off manually by pressing chime on keypad at your selected times.
Run the speaker via the onboard relay, set on / off times for the relay ( note this will turn off all speaker tones ) but you could add another speaker fed from the large keypad to do this and disable chime tones from panel speaker
How do you need it to work?
Auto chime (custom output 2A) is one possibility maybe
the other requires a spare zone, allocated to a spare area and that set to chime with an output programmed up for when the zones go active and the timer is in play.
You can group the zones together and then use the zone group feature rather than individual zones.
Managed to look at this again and thank you secureiam, Auto Chime using custom output 2A to control is exactly what I am looking for.
