I recently completed the install of a Texecom Premier 24 system, with the COM2400 communicator module.
I have connected the card up, and also connected the COM1 lead from the main panel board to the COM board.
I have enabled COM2400 in the COM Port Options on the panel for Internal AND COM1.
I believe this is all the setup that should be needed.
I know the COM2400 is working partially as I can get UDL working from another phone line calling in, and it calls back out to the other modem perfectly, and all the upload/download works in Wintex.
The problem I am having is that the SMS doesnt seem to work, Ive tried setting the ARC1 Protocol to: SMS Messaging, and then setting my number in there as the primary number.
I've also set it in the PAD ARC1 Primary number field (though im not 100% sure what a PAD ARC is) as this is where the SMS centre numbers are (I imagined they would be in the same place as where i setup my phone under ARC1 for SMS but they arent)
Should initiating a test call then send an SMS? (I have the test option set for the Digicom)
It seems to say Idle, Waiting.. so I press 1 which gets it going, and it says Waiting Dial tone, then waiting connect (no dialling)..
When I had a PC number in the UDL options it started dialling it at this point to that number.. but now nothing happens.. it just sits there.
