Hi, struggling with getting into the Engineering Programming Menu on a Texecom Elite 24 system.
Background: I consider myself an advanced DIYer - for example recently I've installed a HikVision IP CCTV system with no issues at all - or, at least, none reading a few forums couldn't solve! 20 years ago i installed an Accenta G3 in my house. WE got a cat and it fell into disuse. A recent kitchen refurb meant the control panel had to come off and i though it would be a good opportunity to upgrade.
So, using the same wires, I've installed new window contacts, PIRs, Bellbox, panic buttons and keypad all purchased as a Texecom package. I've triple tested all the wiring for continuity and believe it to be sound.
My problem: I cannot access the programming mode. I follow the commissioning guidelines to start (factory default button + kick-start button, releasing default when green 'heartbeat' light is on) and the system goes into alarm which i can cancel by entering the default engineers code on the key pad. The heartbeat light flashes steadily as it should.
No matter what i do i can't get to the 'Confirm Devices' on the Engineering Programming Menu the commissioning guide confidently suggest as the next step.
I've tried logging out (0 & Yes) and then logging back in (using default engineer's code) and tried with the keypad addressing as both '1' and 'Engineers'.
When i enter the Engineers code the keypad cycles through a series of screens:
Box Lid tamper -> Mains power off -> Bell tamper -> panel lid tamper -> confirm devices -> PS Failure -> Zone 001 Tamper through to Zone 008 Tamper -> Alarm from Zone: Zone 001 Active through to Zone 008 Active -> Call Alarm Co. For service. -> Power O/P Fault System 12v and then settles with the display 'System Alerts! with the time/day displayed.
Pressing '1' to access Zone Set-up does nothing.
Note: I haven't tried using the Wintex software and (i) i don't have a cable (£40 ish) and (ii) i don't have the software which I understand is restricted to professional installers only. I was hoping to do it the hard way.
I do have a SmartCom to install (still in box) but understand that it not relly possible to program the system via the app.
Any pointers much appreciated.
