Texecom elite + smartcom
3 Aug 2024
Hi
I had a working setup up for years until I could no longer connect to my panel using the app.
The smartcom is flashing blue on the cloud so I reset the WiFi and reconnected - no luck.
I’m able to get into the user menu, choose enable Texecom connect app which I generate, created a new account and the code was accepted. No installer code was required.
Despite this, I still got the error of - failed to connect to panel, please check your internet connection. This is despite receiving push notifications still when I change the time etc so there must be some connection to the cloud.
I did drastic measures of disconnecting power etc and doing all steps again but no luck.
I’m pulling my air out! Any ideas?
There are no faults displayed on the panel.
Version 1 or 2 app ? ( version 1 worked straight from the app , version 2 you had to set up an account via texecom )
How old is the system
!solved - cycled the power on the smartcon and it connected.
