Evening all
After realising that I’m on version 3 of the firmware on my 48-W alarm I’ve decided to update it so that I can get texecom connect.
I’ve purchased a usb com and a flasher and have successfully backed up the panel on wintex.
I came to flash the panel with the new software and I’ve had an issue.
On the download section on texecoms website it only lists the very first version of V4 as a download. I have tried to flash that to the panel following the instructions precisely.
When I click flash the warning pop up comes up about ensuring you have backed the panel up as it will need factory resetting. Click ok past that and it tells you to ensure the flasher switch is in program mode and to press reset on it. Do that and then click ok. I then get the following:
Establishing comms failed: board failed to respond correctly.
The only thing I could find on the internet about the issue is some blog from a chap who had the same problem and resolved it using a newer laptop. I have done this and still get the same issue.
Any ideas? Hoping I’m missing something? Or is the flasher likely to be faulty as the usb has worked to back the alarm up.
