Hi, DIY install of a Premier Elite 48 with smartcom.
The problem I have is:
Arming any area through any keypad results in instant silent arming of the area selected (10 seconds silent, I timed it).
things I have tried:
1: I have set and unset instant arm area in order to force the system to accept the setting. So the system is not set to Instant Arm.
2: I have set and unset Silent arm area in order to force the system to accept the setting. So the system is not set to Silent Arm.
The panel was flash upgraded by through Texecom Connect as was the smartcom. Both now on the latest versions.
1. 2 areas, House and cellar. I need the cellar armed 24/7 unless we are in it, hence 2 areas to stop other users of the system from accidentally disarming the cellar.
2. 2 keypads, cellar and house.
3. Key pad in cellar can set both areas ( house and cellar) because it has an external door.
4. Keypad in the house can only set the House area.
5. both areas can be set through the Connect App and these both go through the timed exit sequence ( I disabled silent instant arm for the connect app to trouble shoot). no problem with arming the system.
this was why I disable the silent arm instant for the connect app, so the connect app starts the proper timed sequence with continuous exit tone etc etc. I my view, the connect app would then use the same settings as a keypad would.
Have I missed another way to set Instant Silent Arm somewhere?
any ideas? I do not have access to wintex so have programmed it via the keypad.
