Texecom premier 412 internal siren
23 Jul 2012
Hi!
here is my ,,new to the forum" post!
I installed like 6 months ago a Texecom 412 cental with a lcd panel and an external sounder (odyssey). So far everithing fine, but yersterday during an output test, I noticed that the internal siren of the central does not sound, only the extenal siren and the the speaker of the pannel. I remenber having heard the three sound when I installed them! Do you think the one inside the central will not sound afer having installed an external one?
Many thanks in advance for your comments! :D
Did you fit a speaker or a sounder ? if you fitted a speaker is the output programmed for a speaker ? and the same if you fitted a sounder is it programmed for a sounder see page 34 and 35 in the programming manual.
I did fit nothig, the central comes with a speaker (I think it is one because of the noise it made). What I do not understand is why at the beginnig everytihing sound and now only the speaker in the control pannel does!
:confused:
Just checked again the config. the output for the internal speaker is enabled, still the only sound I get os from the pannel and not from the central! Any ideas?
Many thanks again!!
how many sounders do you have ? i assume 1 x internal speaker ? and 1 x external bell box, what else ?
Yes thats right! The internal built in speaker in the central and a oddissey bell box outside!
dont understand. you start by saying you dont get internal sounds and later you are saying you are only getting internal sounds ? ? ? which in not working ? ? ?
Okay. So I get sounds from the outside siren, the speaker in the lcd pannel, but not from speaker inside the central! I remember having heard it when I installed it.
ok remove speaker check with multimeter set on ohms should be between 16 and 32 ohms if no reading its blown replace.
