Texecom premier 48
10 Aug 2012
Nottingham
Hi, I have a texecom premier 48 which has ATS (alarm transmission system) path fault. Can anybody help.? Thanks.
phone line fault or other path depending on comms. but chance is the phone line. ( have you swopped or cancelled a phone line ? )
pay as you go sim ? have you done a test every month ? if not may have run out if not used...
MAY be on engineer reset for ats fault. if you have engineer code enter it press reset menu exit eng yes. see if that clears it.
Hi, yes we have the eng. code and have been able to reset this fault. So far no more problems. Thanks for your help.
