Hi
First time I've ventured into the alarms forum - loaded with info!
I've just moved house and need to install an alarm (wired). I've done a couple before, am familiar with EOL wiring etc but this house is bigger than I've done before. I'm looking at about 60 zones in all when everything's included (three stories, triple garage with upstairs etc, sheds).
I've come to the conclusion I need a Texecom Premier 88 - everything I've read here about them is very positive, and a good manual is always useful. The issue though is this: It seems I can't use the onboard zone expanders (8XE) as they're only for use on the Premier 24. The remote expanders are twice the price (£42 each vs £23 each for the onboard) and it's going to add a load more expense to the project.
It seems the MUCH cheaper way to go is the 60 iXD - £57 gets me 60 zones. The problem is I can't find many posts (here or elsewhere) with much good to say about iD biscuit systems. Harder fault-finding, more prone to static, need to use shielded cable etc.
How would you pro's do it? Would you spend the extra on the remote zone expanders and stick with EOL, or go with iD biscuits? This must be a pretty common problem for you guys - whenever you're wiring a big place?
Thanks in advance.
James.
Thanks in advance.
James.
