Texecom Premier Alarm - 2 sensors must activate before alarm triggers
21 Sep 2013
Lancashire
Might be a strange question but is there a simple way change a setting on the control panel so that the alarm will only trigger if 2 sensors are activated. We are getting quite a few false alarms and this would solve our problem.
Thanks in advance for any advice. :)
Why are you getting false alarms ?
I think it is due to the tempurature changes as we don't have dual tech pirs. Rather than change all our sensors if there was a possibility that 2 would need to be triggered before the alarm goes off that would work perfectly for us for the time being.
I wouldn’t recommend it ….
Post pictures of detectors false alarming
How old is the alarm panel and battery ?
When was it looked at last ?
Enable Beam Pair attribute on Zone settings for the two devices you want, best solution would be to find what's causing the alarms however.
