Hi, just after some help. After 4 years of zero false alarms from my Premier Elite alarm I have had two in the past week. All from the same sensor which is in the shed. It is a Ricochet DT-W Dual Tech PIR and I can see no obvious problem with it, the battery is fairly new and doesn’t show any faults on ricochet monitor or wintex. The only thing I have noticed when looking tonight, there was a spider sat on the side of the sensor so wondering if the little git has been running over it ?? Can a spider trigger a dual tech ? I brushed it away along with the web so hoping that that’s it. Could it be anything else ? Faulty sensor ? I just find it quite hard to believe this is the first time in 4 years a spider has run across the sensor.....inside a shed? It’s bloody riddled with the things Also, the last false alarm happened within seconds on being armed, I was literally just pulling off the drive in my car and the alarm went off....shed PIR. I got out, cancelled and reset and then was fine.
Many thanks
Andy
Texecom Premier Elite 24 Polymer
Richochet 8XP-W Expander
Connect Smart Com
Many thanks
Andy
Connect Smart Com
