Hi, Im having trouble setting my telecom up correct, the set up is:
1 PIR upstairs
3 PIRS Downstairs
Keypad by front door,
I require 2 alarms
1: full alarm
2: part alarm with the 1 PIR upstairs disabled & Silent
I have the majority of the set up correct as above however I'm having 2 major problems:
1: the PIR by the front door is set up as exit mode & all other PIRs are set to guard mode with a 45 second timer to leave, however when any of the alarms are triggered is is creating a arm failure.
2: i can set the alarm with the passcode but to disable the alarm i require a PIR tag. This seem not right as i could easily forget the tag.
Any help would be appreciated.
Thank you
Mike
1 PIR upstairs
3 PIRS Downstairs
I require 2 alarms
1: full alarm
Thank you
Mike
