I have a COMIP connected to my premier elite 48, using it I can connect to the panel from Wintex and the android app and everything is reliable.
The module is connected to COM2, the problem I have is that it only seems to work if I leave the port configuration for COM2 as not used. Setting the COM2 port configuration to COMIP results in no communications with the panel. I can still ping the module at this point!
Anyone else seen a similar issue and what are the disadvantages to just leaving the COM2 setting set as "not used"?
