hi
going to be installing a wired texecom system myself with any necessary support form a work colleague (who is a qualified spark and ex alarm installer). he hasn't installed alarms for a few years so isn't up to speed current systems etc. I want to do as much as i can without bothering him tbh if i can but good to know he's there should i get seriously stuck.
anyway, been doing some reading and have decided on texecom products. Thinking of the below components :-
Premier elite 24 or 48 control panel
x2 keypads
x6-8 Pet PIR (for x2 cats which are best?)
texecom ethernet module
x 2 external sounders
Battery
x2-3 smartkey (if can be used)
the house is in the middle of renovations so it is the ideal time to run wires etc so no worried there. the plan is to have the control panel in the garage (which is integral to the house) with a keypad.
then a second keypad next to the front door.
x1 sounders on each gable end and the pirs around the house at various locations.
does that sound like a viable system?
should i go for the 24 or 48 control panel in a 4 bedroom house?
could i add wireless PIR's down the line at a later date? (for planed sheds etc)
Can i use the smartkey fobs with the above wired system?
the garage has an electric door, can i use the above smartkey to control it and arm disarm the alarm?
any other advice welcome, many thaks for your time
x2 keypads
Battery
