Texecom premier
8 Jul 2017
ive recently changed router and it has a different ip range to the previous one. My texecom premier was setup as a static ip. I need to change it to dhcp so I can see it on the network and thn be able to integrate it to my home automation. Do I need to crash the alarm and thn reprogram it from factory reset. Or is there another way?
Possibly via the keypad. I do not have wintex
Thanks in advance.
UDL/digi options , arrow down to set up modules, press yes, arrow down to setup ip data , press yes ....there you go...
If I do this, everything else on the network won't work.
Doing it via the keypad has worked a treat.
Thanks for your input though.
If swapping a router, if you keep the subnet the same, then no devices would need any alterations. Too late if it was only the Texecom left to swap IP.
