A few niggly questions that I've stored up for a while.
Cheers!
- The "part" and "area" buttons don't arm the system when using the app or Wintex keypad. They work fine from the physical keypads. I am using keypad areas, but not area arm suites. I guess it is because the app and Wintex keypads are not set to a particular area? Is there a way to do this?
- For the bedroom keypad, I would like entry and exit tones enabled for some areas, but not others. I can only see the one option for entry/exit tones for all areas. Is there a way to do this?
- I would like the house to auto part arm after 1 hour of the back door and front door contacts being continuously closed. These contacts along with the rest of the house are on area A. I have set auto arm area A, part arm instant area A, and auto part arm area A options. I already have the garage (on area B) auto full arming after an hour which works fine. I do have PIRs in the house that are set to "part arm omit" and guard access. Would "part arm omit" stop the PIRs resetting the 1 hour timer? My problem is that Area A does not auto part arm. , or is there anything else I should check? I could move the part arm zones (front and back doors) to a different area and have that area auto arm instead.
- I have 10 ricochet window contacts. These contacts are set to always awake, and these zones are mostly always armed. The area with the window contacts is set to auto arm after 1 hour of closed windows. The batteries in some of these contacts only seem to last 2 or 3 months. Is this normal? Ricochet network seems ok, I can post a screenshot if that would help.
Cheers!
