Hi All,
I have a Texecom Ricochet Premier Elite 64 system with a Odyssey-W sounder.
The sounder batteries were low but by the time I got a ladder that was long enough to reach the batteries were completely flat and I was unable to arm the system at all. I was getting supervision faults and it would get stuck on preparing to arm.
After changing the batteries the Ricochet monitor could see it again and no longer reported low batteries - everything is green except for Extended Tones which is red. The keypad still says system errors, cycles between radio conf fail and supervision fault both for the sounder, and it still gets stuck on preparing to arm.
How can I get the system back up and running again? Do I need to remove the sounder altogether and re-learn it?
Thank you
Thank you
