TFU with new pasterboard ceiling
31 Dec 2005
Lanarkshire
Put up a new 'lowered ceiling' with 12mm plasterboard in the bathroom - the boards came from B&Q and did not have the dropped thinner edge for taping - so like a clown i did not tape/fill the joints - i did not see this as a problem as all the joins (2 across the room) were finished edge - edge to edge no gap joins. Also we were going to double cross line the plasterboard before painting the ceiling so i expected even one layer of the lining paper to bridge this join without any problems. Having decided to keep the old art decco centre light fitting and not fitting downlighters we find that even with two layers of 1200 lining paper at 90 degrees we can see slight shadow shallow depressions in the lining paper where the boards join. Having a bulb at ceiling height is of course the worst possible lighting conditions and shows this boo boo up very obviously - even after two coats of paint. We have just totally refurbished the bathroom and this issue is spoiling a really nicely finished room.
Any quick fixes or do i have to remove the lining paper (now under the cornice - we lined the ceiling before installing the cornice) and start again after skimming the joints.
Ideas suggestions PLEASE!!!
thanks
David
Any quick fixes
No not really. You must always tape the joins regardless or it will show & any filler will crack.
Remove the lining paper (if you can), undercut it off at the cornice with a Stanley knife, tape the joins & get the whole ceiling skimmed. It will look much better than lining paper which your taking a big risk with in a damp bathroom environment anyway.
Taper edge boards are intended for tape & fill (personally I hate it), if you tape & fill square edge boards, you will have to blend in over a very large area to “loose” the join; you might as well do a proper job & get the whole ceiling skimmed.
If you want it to look it's best David, you will have to take the paper off, tape the joints and sand them down,,,, then after priming the ceiling, you could re-paper it. If it was me though, i'd tape the joints, skim the ceiling, then emulsion it,, saves papering it.
youngroughcaster ;) ;)
as above i would take richards and yrc advice cut it at the cornice take it off and skim even if you couldn't see it through the paper i suspect you will soon have cracks running along where you didn't tape it, no quick fixes im afraid but not hard to do and less than a days work
