Having had a new boiler installed and looked up the information on balancing the radiators in the house could somebody explain to a beginner why you balance them up with all thermostatic valves on max? i.e. My Westherm on position 5.
I understand the balancing of the system for the required temp drop on the outlet and the bypass valve adjustment but I never have my thermostats at full blast in the house. Around one third of my rads are set to position 2 on the Westtherm. Only the main living room is set to 4 out of 5 and two rooms not used are on tick over at 1.
So as this is my normal running set up for many years in the house why would you not adjust the balance of the rads with these actual real live settings? Many thanks for your patience as I am not a CH plumber. Open vent condenser boiler runs at around 72*C and return is around 52*C at plus 6*C outside temp.
