- Joined
- 27 Jan 2008
- Messages
- 24,925
- Reaction score
- 2,882
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
We see on here again and again "Can I" do this. And of course since we don't know the ability of the guy or availability of test equipment normally a simple answer is not possible.
Should we try to explain or should we just say likely no you can't?
With most DIY people they will not have access to test equipment so under the BS7671:2008 rules they can not do the whole job themselves. So likely most "Can I" questions could be answered "Likely no" but do we look at BS7671:2008 or just Part P?
Is Part P making electrics more dangerous when if asked "Can I" we answer yes as Part P permits it even though likely under BS7671:2008 they would be unable to comply?
If we say No will the advise be ignored and would it be better to say yes if you and explain what is required? If so should we have standard answers for the repeat questions?
Should we just reply with assuming you have the skill, knowledge and equipment. Or should we assume since they have asked the question they don't have the skill, knowledge and equipment?
Thoughts please.
Thoughts please.
