hi new here hoping someone can help
my vivaro 57 plate 2.0 as started blowing white smoke this is only in the morning after its been sat over night and if I sit there just letting it tick over.
how ever if I drive it after about 5 mins or so the smoking stops. if I then pull over and let it tick over there is no smoke.
I have noticed that my temp gauge on my dash does not move at all could the 2 be linked??
I was also short on power until about 20000rpm then it would be fine.
I have replaced the glow plugs the MAF sensor and the boost solenoid an the slight power loss seems to have gone. I should point out I have also bought genuine parts not cheap ebay parts
I don't appear to be loosing any coolant or oil so im starting to think either the head is gone or its the injectors?
however the van does not tick over or run rough its seems fine apart from this white smoke any advise is very welcome
thanks in advance
thanks in advance
