Dear All
Any tips for removing a very solid bath tap please?
It is fitted to a cast iron bath at a friends which is staying. Got one tap off after lot of work with blowtorch on the nut. Same has not worked on this the harder to reach one. Have broken tap spanner on it. Tried large adjustable as there is just enough room to swing it between nut and wall.
All I can think off is to use a grinder- hard to get underneath- so cut off tap from above and then grind carefully down until remains can be knocked through.
Any other suggestions please?
