I'm hoping more electrically experienced minds than mine can point me in the right direction, because what's happening seems to defy all logic.
Our 13-year old house is approximately half LED downlighters and half halogen. Three of the halogens have gone intermittent, and one of them stopped working completely a few days ago.
When they go intermittent, they usually come back on if you give the lamp a flick with your finger.
I put a new lamp into the unit that has completely failed, but it doesn't come on. I've tried the lamp in another holder and it works. (And I've tried a different bulb in the failed holder...)
With my multimeter set to 9VDC, I can't get a reading off the bulb holder. I was ready to conclude the transformer had failed, but when I put an LED lamp in there, it flashed continuously, so the transformer must be outputting 12V, or thereabouts. Uh?
As the unit appears to have a transformer attached to it, I assume that if I remove the whole thing and replace it with an LED unit and driver, the fact the rest of the lamps on the circuit are halogen is irrelevant. Correct?
Also, as the unit is in a stairwell, which is the only exit, do the regs say I should install a fire rated unit?
Any help gratefully received.
