I am going to replace some internal doors in the house. Not spending crazy money will be just replacing them with the cheap pre primed 6 panel doors. You might wonder why not get better ones? Well Just dont have budget for spending alot more, and hounestly even though they are cheap they look million times better than my current doors! (Flat door in this ugly mahognnay style thing).
I have found many great videos and tutorials online on how to hang a door, but cannot seem to find any really on how to size up the door, or how to replace a door into an older frame. Most videos are putting a new door into a new frame. Last year I renovated a door downstairs and was not as knowledgeable, hinges dont sit right and it all needs fixing. Which is fine, I am going to do this. I just dont want to have same problems as before!
Few issues I can see;
1 - Current doors are 35mm deep and are not painted. I've noticed all the door jambs are pretty much 35mm deep. As I am painting the new doors with potentially 2 undercoats and 2 top coats, hopefully less, I am concerned about the door being more than 35mm and then it not closing correctly etc. When I was painting other side of door frame, the new paint made some of the doors be a bit sticky as the fit was pretty tight, and that was just from bit of paint "bubbling" at the edge of the jamb. (does that make sense?) I sanded it, but I have not even painted the side where door meets jamb, and it will need painted. I have not painted any of the room sides of the doors, and the frames have had gloss paint on them. Will need sanded etc. What about moving the door jambs? Is this a possibility or would it be easier to try to somehow trim out a mm or 2 ? Not the easiest thing to do. Ive no idea how the jambs have been attached, but it is a 1975 house and most things have been nailed so I doubt its screwed in.
2 - Current hinge sizes are not any size I can find in the shops, so I am either going to be smaller or bigger. I am actually thinking of getting slightly bigger ones for a neater flush finish. Current ones are 90mm in height, so will get 100/102mm ones.
3 - When to paint? So this is something I can't really get an answer on. When should I paint the doors. Before or after hanging them? Reason being about the extra couple mm from paint will effect things? I have sizes of current doors, and can trim to that, but should I be trimming an extra mm off for paint?
Sorry for the wall of text, hopefully someone can help me out a bit at least?
Thanks in advance!
Thanks in advance!
