Hello all,
So far I have always used 2 coats when skimming.
This general rule seemed to let me down recently on a thin section of plasterboard/beading.
The builder did the arch to the left which hid the RSJ, and I did the area over/round the alcove housing the fridge. Two coats were fine inside the alcove and above the fridge etc, but on the RHS 'leg', where the width of this face is only about 8", two coats has now left it slightly proud of the beads and not perfectly smooth.
I plastered this 'leg' by firstly working a bit of plaster into the edge beads, and then following with an upward motion sliding along both the beads (using the long edge of the trowel like a bridge). After the first coat it seemed better than after I finished the second. On the second coat I only did the upward bit.
From this experience, in future, I'm thinking that if the width is less than a trowel length, you're ok and neater with just the 1 coat. Is this an ok rule, or is there a better way to approach this?
Thanks as always.
Thanks as always.
