The hot water comes out of the bath mixer tap/shower slowly - 20+ secs/litre compared to 8secs/litre from the hot tap in the basin. Both come from the same pipe from the hot water tank. I guess there is a branch somewhere under the floorboards to split the flow. The taps can be isolated from the pipes (which are the originals 35 years old) by newish stopcocks installed when the bath/basin etc were replaced by a professional.
I have removed, and successfully replaced, the hot tap and the valve that directs the flow to the tap/shower. Nothing appeared to be wrong.
Recently I replaced the shower hose from the mixer tap. There was a couple of days when no hose was attached. My wife tells me the slow flow of hot water started then. The cold water flows at normal rates through the tap and the shower so I don't see that the new hose is a problem. I haven't touched any of the copper pipework.
Do I have a stuck, half-open, non-return valve somewhere in the system?
Any other ideas?
Any other ideas?
