OK here goes.
I'm not a builder by any description but I'll have a go at most things provided I'm sure things are ok.
To set the scene:
I want to board my loft to use as a general storage area, boxes and such, nothing heavier than me.
I have a timber framed house which seams very sturdy but the joists in the loft are very shallow, 2" shallow in fact. I can stand on them without feeling any movemet, but I suppose that doesn't mean anything in the grand scheme of things.
I want to pull out the old mineral fibre insulation and tidy things up before dropping in new stuff.
Insulation regs say 200mm which is a real pain for me as the joists are only 50mm so increasing the height is going to be a laff.
I came up with an idea to use YBS super quilt, 25mm thick but with properties of 200mm fibre, great....not.
YBS original told me it was fine to use, but then (after I had bought £1400 worth) told me that it can only be attached on the pitched section and cannot lay flat in between the joists on the floor..er..ceiling..whatever.
The frames in the loft are W shaped, if that means anything to anyone, and the electric cables run over the top of the joists....another pain.
Ok, scene set...now for questions.
Should I give up now as my loft just won't take it? (I'll still re-insulate, just not board)
How can/should I raise the effective height of the joists to combat the cabling/insulation depth problem?
I now know super quilt has got to go on the pitch but can loft quilt sold by screwfix be laid flat as a replacement to mineral fibre?
Does anyone want to buy 6 unopened rolls of super quilt off me for £1200 if I can't use it hehe?
Why is it that vitrually everyone I know store things in the loft but lofts only ever designed to hold the roof up?
Thanks in advance for any feedback.
Jim
To set the scene:
Jim
