I have a customer - an infirm couple - with 8 candle lamps in their sitting room. Every time one of the candle lamps blows, the MCB trips. Changing the fittings is not an option.
I've tried replacing the MCB with a 6A type "C" and tried a couple of different manufacturers for the candle lamps, all with no improvement.
My multimeter shows that the supply is frequently towards the top end of the allowable voltage range.
I guess I could inspect and test the entire circuit then uprate it to 10A, but I'm wondering if changing the light switch might be a solution. Does anyone know of an easy-to-use switch that ramps up and down smoothly? And do such switches really fix the MCB trip problem or do they just extend lamp life a little?
Clearly touch switches and rotary dimmers are out. A standard MK white plastic switch is fitted at the moment.
Michael
Michael
